As I bought my Naim separates in 2014 and weren’t new back then I wanted to touch on servicing.
As they haven’t been serviced for many years I presume the advice would be …get them serviced. But what would be the order …
Firstly is there any tale tell signs that say you should defo get that separate serviced first …maybe humming etc?
Secondly … would it be based on price …most expensive first
Thirdly … Amps before pre amps
Also do Hi caps and/or Napsc need servicing
You can tell because they sound a lot better when they come back!
I had a 250 suddenly sound a bit off when overdue some attention but generally I think the changes are slow so you don’t notice until they are refreshed.
Well, from experience, they will be underway for a good while. When you don’t have spare components to swap in (some do, but not everyone) you might as well send in the whole enchilada, and ask your dealer for a Muso/Atom/something on loan, or buy/sell one yourself.
If all that fits your budget of course, servicing has a price and getting stuff DR-ed can be an investment (see the 2022 service/upgrade price list in another recent thread).
As always, contact your dealer/distributor for advice, they will handle things anyway. Unless you’re in the UK where you can also contact Class A directly for guidance (and shorter turnaround).
This is exactly what I was looking for, really useful thanks Ian
Many moons ago I am sure Naim would allow direct sending of Naim back to them, isnt it bit fussy having to go through a shop! I don’t want to be sold anything I just want to improve my lovely Naim
