Looked for an answer, but couldn’t find one.
Can you set the sleep timer using the Nova remote? The Muso 2 remote?
You use the app.
The Nova remote functionalities :
Back button — Used to go back to the previous screen.
Thanks. There’s also a clock button. I thought maybe I could use that to set the timer.
FR missed points 1-9
I badly copied and pasted apparently. Thanks to providing the beginning
Nice I will have to copy some of this to my own notes about the remote.
But it is really strange my favorits button does not switch among favorits as indicated. But at least in activates my most use internet radio favorit on the 555.
Claus
I would like to help, but unfortunately don’t have a Nova.
Maybe @Naim.Marketing should be able to give you an answer.
You can scroll through presets, but not favourites on your Uniti Nova remote control. (Favourites are solely App based.) A reminder re presets:
On Uniti Atom, Star or Nova systems, plus ND 5 XS2, NDX 2 and ND 555 players (running software version 3.5 or higher), you can create unlimited numbers of Presets from your favourite Internet Radio Stations, or Qobuz, Spotify and Tidal playlists, albums and tracks. Scroll through your Presets on the front panel of your streamer, including using your remote control handset, or see and arrange your Presets in the App.
Yes I mixzed presets and favorits! and now it works 30 percent of the time. You need to press the favorits twice to switch to the next favorit. If you press it too slow or too fast it does not work, it seems you have to do it just the right way! When it works it seem to work consistantly but sometimes a press of home first seems to increase the chance of this working!
Claus
