If you require a PLL cable that is shorter than 2m, is it possible to cut the cable and rewire the Naim 3-pin mains plug?
Yes - inside it’s a standard 13A plug. Can you not just hide the longer length rather than shortening it ?
Yes it’s possible, I only need about 70cm length with my two.
However as it not just any ol’ 3 core & might one day have a resale value if it’s the original length, & as it’s well hidden, I chose to fold mine & to bind the folds with velcro tape.
There’s precious little space behind my rack - it’s positioned between the chimney and the arc of an opening door.
I thought the lites were normal leads but with decoupled plugs on the end.
Just a decoupled mains plug. Standard IEC.
