I can live with
No , just to catch your attention
I’ll ask for your advise when they go flaccid
I can live with
Very very nice cart that Hana, excellent VFM as they say the hana hits well above its pay level. I have a friend who has one on his SP 10 and “the wand tone arm” jaw dropping good, does every right!
Congratulations on the P10 and Hana cartridge - lovely. I’ve been reading quite a few positive comments about the Hana/ Rega pairing as they seem to contemplate each other beautifully. Hana Unami next? (!)
At the Rega P10 level I would be very tempted to investigate the Rega P8/P10 dedicated wall shelf to complete the set up, just allowing the record player to perform optimally, as opposed to the third party isolation feet, which could be compromising performance and adding their own sound signature. Just an observation.
Thanks YetiZone , actually this is my first priority a wall bracket but I have 65” (with its speakers it makes 75” or more ) TV that has taken most of the space and the P10 RCI/PSU cable length that make it hard to find a location for a wall bracket and I need a powerful drill for the concrete too( the one that I have is not powerful enough) it will take time but I’m working on it
Ouch My XV1-S suffered a similar fate. I have since learnt to put the stylus guard back on after every listening session.
Do you know the size of the drill bit that you used for the shelf and the length of the screw because I can’t find the detail on the internet
Thanks in advance
Hi b
I think the drill bit was number 10 if I remember correctly, the length of the screw I can’t remember but it was longer than I would have thought it needed to be. Hope that helps.
Ariston Q Deck , very kindly given to me by a friend. Very temporary installation I’ll tidy it up soon. To be used in spare room system.
They were excellent decks.
Drool time
What do you think about the PU7 vs other tonearms? I had my Akito arm upgraded by Audio Origami and is now very good.
Let me know your thoughts.
Thanks, Dan
I’ve had Logic tempo, an LP12 lingo, Ekos, Troika.
Voyd.5 then Roksan Radius , dalliance with DD Technics and now back with another Voyd lexan platter SME V Hana SL.
And very good it is too.
Streets better than the Ittok, and Akito. It’s up there with the Ekos SE/1 and Aro. sound wise it fits in nicely between the two. Gives you a good bit of that magic of the Aro with the extension and weight and extension of the Ekos SE/1
Thanks sounds like a very good option for future consideration!
Does the Voyd work well with a SME V?
Only heard Voyd turntables with Helius tonearms.
