Hi,
Happy user of a MU-SO QB2. I was wondering if there is a way to shuffle all songs on a USB stick?
Thanks in advance
/M
Hi,
Thanks in advance
/M
I love that you’re using A Broken Frame to illustrate this. But will that shuffle songs across folders or just the current folder?
It will shuffle the current playlist. So if you’ve started an album, it will shuffle the album.
Probably the simplest solution is to create a single playlist from the entire contents of the usb stick, then shuffle it.
But that’ll only work if there are fewer than 500 tracks.
Thanks for the replies!!
Well, it would be a nice feature IMHO
Dear god no!
