Silent Angel Bonn NX
Anyone with experience with this switch (and/or the GX clock within the same series)?
Anyone who doesn’t believe that clocks or networking devices can make a difference please save me your contribution.
Had one for a while. Made a positive difference,if subtle. Easily impeoved upon by what I now use; Gustard N18 pro: much ‘better’. Inbuilt LPSU plus high quality construction & components.
It has an external clock input which I did try: no discernible difference. The only benefit a xlock may bring is lower noise,
Network tweaks are very, very system dependent. Worth experimenting with though.
The NX costs €3600 and is bettered by a €529 switch by Gustard?
Aren’t you taking about the standard Bonn N8?
If you Click here you find an ealier discussion about this topic. Maybe @MangoMonkey can comment about his further experience with the Bonn NX.
Ah, sorry. Standard N8. If you’re in the market at that kind of spend, I’d be thinking about a new Dela S50, or a good used Melco S10.
Worth trying the Gustard though; it might well be all you need. It does perform well above its price point.
I sold recently my Phoenixnet. For financial needs. After 10 days running of my new EE8, i am very surprised to discover that the former is not superior in all aspects.
The Phoenixnet costs 6 times more.
It’s fuller vs the EE8, but the EE8 gives a snappier bass and is more groovy. On my new system with the Lumin Mini U2 as transport into Nds .
Have not compared with bare Nds.
How does your Denon CD player sound compared to your streaming setup.
Interesting question!
Using it as a transport in to my Moon 390: very similar to local file playback via Roon. Has a slight edge over Qobuz (comparing same ‘versions’ as far as I can determine.
As an integrated player using analogue out to 390: quite a different presentation which is unsurprising a the 390 and 1700 use different DACs, power supplies, etc. warmer sound but not quite as resolving. Using good SACDs (why I use it!) then the 1700ne comes in to its own. Extermely good and much ‘better than Qobuz or local file. I did listen again recently to the SACD version of ‘In A Silent Way’; the SACd version is sublime.
The 1700NE is underrated, imo. Tremendous value at around £1k; worth taking a listen to if in the market. It’s also really well put together and more or less silent in operation.
Thanks.
I’m considering buying a CD player, it will probably be the 1700ne or 3000ne.
Looking at reviews, they both seem to be top of the pile in their price bracket.
I have the DP3000NE/DL103 turntable, very impressed, produces a beautiful, balanced and musical sound, no matter the genre or production quality.
Although obviously there are exceptions. :grinning_face:
I would have had the 3000ne, but it’s just too heavy for me these days :thinking:
Could we get back on topic please :folded_hands:
Any further experiences?
@MangoMonkey
Did you get another FX after you accidentally sold it on?
„Off The Wall Audio” (a Naim Hi-Fi dealer from the Netherlands) has published a new review (Silent Angel Bonn NX, Genesis GX, Forester FX). What’s interesting is that they’re using a Naim NSS333, Nac332+NPX300 with Powerlines, and ATC SCM40 active speakers as their test system.
Result: The Bonn NX significantly improves the system’s performance, enhancing PRAT without compromising tonal balance. The Genesis GX refines the soundstage but doesn’t make as big a difference as the NX. The Forester FX is almost too much for this setup and tends to shift the soundstage toward a more Hi-Fi-oriented sound.
An exciting report, in my opinion—you can find it on Google by searching for “off the wall audio netherlands” under the “Nieuws” section. The original text is in Dutch, but Deepl or Google Translater can help….)
