Hello all, hope you’re keeping safe and well.
I have combined my AV and music systems for as long as I can remember and it’s always worked well. A low level signal from my Yamaha AV amp to the N272 for the front left and right speakers means I get the best of both worlds for music and video.
The AV amp is getting on a bit now, but the real (first world) problem is that it’s so big and there are so many features that I don’t use - even more so on the newer amps. I’m looking to tidy up the boxes and get a better rack (probably Fraim) and the standard AV amp would look a bit odd.
I am looking for a smaller, more simple amp that only needs to do the following:-
Good quality signal processing (5.1 is enough for me).
Low level signal out for the front right and left speakers.
Amps for the centre and two rear speakers.
A sub-out.
Smaller compact size.
Does such a product exist? I’ve had a look and couldn’t find one so I thought I’d ask the question.
Matthew
