Simple question - Din Xlr
Is a NAP300 4din to xlr pair the same as two NAP250 4din to xlr single cables?
The NAP300 (and 500) DIN4 to XLR cables are handed and wired as a mono cable only (red band, right, green band left). The 250 DIN4 to XLR cable is wired for both channels. You could use a pair of 250 cables with a 300.
300DR cables are wired for 1 channel.
DIN to XLR (250) carries both channels.
Someone on forum tried 2x250 cables with a 300 and, whilst they worked, sounded not as good.
Thanks for explanation replies, stick to dedicated pairs… you have to pick possible shortcuts carefully in this game :slight_smile:
