Site errors
Is the site currently experiencing difficulties? Update to followed threads are not showing on main page, only when trawling through site history.
Also the Categories no longer has the Unread (I think it was called) category, which is a pain. I now have to go to New and work my way through that to find the topics I was following.
Was this a planned change to the site?
No idea - I have not seen any discussion of it.
There was a change a couple of days ago that apparently Richard had not expected, which introduced additional emoji comments to the ā€˜like’ button and enables people to see who has liked a post, and also introduced a new category ā€œuncategorizedā€(!), with a brief flurry of amused comment from members before disappearing, presumably disabled by Naim moderators. I assume that platform update must have carried these other changes. If an issue then best flag Richard.
If it is a planned move, then it’s a backward step to remove the ā€œunreadā€ tab.
As with the other changes I had seen it may have been done by the platform provider, Discourse, with Naim having no knowledge or input.
I have noticed that likes don’t show unless the page is refreshed.
Not major
But I don’t seem to be able to edit my posts the edit box comes up and I do what is needed but it won’t upload.
The only way I’ve found round is to delete my post refresh the page the make a new post avoiding repeat as it won’t accept that either.
Edit works fine. Sometimes you need to refresh the page in order for the edit to show, as previously.
Happy to give you a like if that helps :+1:
I would have thought that Naim or @Richard.Dane would have been informed of upcoming changes. Maybe AI is now in control. :blush::firecracker:
There was Discourse update a couples of days back. As ever, this has various tweaks and ā€œimprovementsā€ by the Discourse team, as well as other less visible things to keep the site up to date. This was, of course, planned in advance by our Web Dev. However, there was one unexpected thing which was the appearance of a new mystery ā€œuncategorisedā€ room - now removed.
You may though find that the update has meant that read parameters (read/unread etc..) have been reset.
I wonder whether this has fixed the issue I have with photo icon not working?
I usually have to cut and paste on my iPad. I’ll report back …
If anyone finds the best way of accessing unread topics, please post it here.
Maybe the last visit line would work for you.
Does the following link work?
https://community.naimaudio.com/unread
I had a challenge with that and found it was connected with the tick below this window. If I clicked the cursor where I wanted to insert the picture, then clicked the tick to remove that bit of the window and then clicked the picture icon it worked. (Screenshot taken on phone as I’m on a train into town.) It happened on my ancient IPad and not on my newer phone.
That works - so it is just that the menu entry for it is missing - indeed, unavailable.
I posted this on another thread
This is a workaround:
click on the 3x bars and choose the + to add a custom section
Use the link posted above and create the section
once done go to your profile and preferences > Interface and change the homepage to your new custom section called ā€œunreadā€
Now when you open the page or click the ā€˜naim’ home button it shows unread
