As the title says, does anyone know the thickness of the SL2 spacers washers (including the tiny nodules)
On mine the tiny nodules have worn away
Are Naim unable to supply replacements? I would definitely try to stick to the correct parts as the spacers are very much a part of the overall design. IIRC the nodules on some batches are flattened on the top - be sure you’re not mistaking that for being worn.
I’ve tried Naim - no longer available
The speakers I’ve acquired came with 2 unused ones - these have definite bumps on them. The ones that were installed feel completely flattened
Try Tom Tom
+1 for Tomtom. They have what I think you’re after. Happy new speakers!
@Michaelb Thanks - they’re not showing them on their website, but a quick phonecall - all sorted
That’s great news. Well done James!
