No, I don’t believe so… which is why you use an UN-BAL.
Ok, thanks. I assumed that the AE1s XLR inputs were designed to be connected to a +4dBu pro line level signal and that an active DI would be better for long lenght cables.
The AE1a work perfectly… the levels between unbalanced and balanced seem consistent. The input sensitivity is listed as 104dB for 1VRMS @ 1kHz.
I use quality professional XLR leads, with low resistance and good shielding.
