Just bought smoked glass unit from Richer sounds, all sky , dvd, etc all units work with remote apart from Naim 172 pre amp, any ideas?
The IR sensor for the 172 is built into the logo. Are you obstructing this in some way with the new cabinet ?
Thanks for reply, problem solved, I just noticed the glass is a solid black for about 1 inch around its border masking the logo, I put the preamp on some hi Fi feet to raise it , …problem solved.
Oh good - enjoy your new cabinet !
