I want to use Caigs Deoxit spray on my SN2 volume pot
The left speaker makes a KRRRRK sound every time i use it ( remote or manually ).
The right one is fine.
I had a same issue with my Naim Nait 5i-2 and i opened the top cover used the deoxit spray and its working fine since the last 2 years. The Naim Nait 5i2 top cover loosening bolts are easier to figure out ( for me )
Thing is i am unable to figure out what to loosen on the SN2 to open the top plate / cover.
There are 4 feet on the bottom and i see 4 allen bolts as well…
Can somebody guide me correctly ?
Thanks !
FAQ 1 : I dont want to do thru a dealer. I am too far away
FAQ2 : Naim support is OK to use Caigs Deoxit since it appears to be a dust issue.
In November 2019 i had asked them but but i carried on till now - till i could live with it. But now i think its high time i must solve this.
Normally I would always recommend that you go to a dealer. Opening up the cases is not really for the end user. It’s very easy to screw things up. I’ve seen a number of cases where someone has tried to open up the case using inadequate or ill-fitting allen keys, and they have rounded out the hex insets. This is easily done as the bolts need to be done up very tightly to ensure that the heat-sinking works correctly. The only solution then is a return to the factory where the bolts have to be carefully drilled out.
However, that said, the feet and all the bolts need to be removed. Be very careful with the three smaller ones in a row as I think they hold the sinks for the output devices in place. If in any doubt whatsoever, please liaise with Naim’s service department for advice and guidance.
