SN3 Alps Velvet vs remote
Hi,
When we don’t use pots manually they kinda develop issues over time. But in case of alps Velvet used in naim sn3 abs preamp, they rotate with the remote, does this mean the pots are getting the exercise needed?
When you use the remote controls, all you’re doing is commanding motors to turn the pots instead of you doing it manually yourself.
