SNAIC 5 pin for CD5si?
Hello! I had a quick question. Can you use a SNAIC interconnect to connect a Naim NaitXS with a CD5SI? It looks like the SNAIC is usually used to connect with external power supplies but I was wondering if it would act as an upgrade from the basic 5 pin to 5 pin interconnect.
No it can’t be used, the pin configurations are different.
The IC pins are 180 degrees
SNAIC pins are 240 degrees
Ah ok, good to know. Thanks!
