Snaxo 242
Hi
Just about to set up my SNAXO 242 and there doesn’t appear to be any transit screws on the 242 the 362 instructions show two transit screws that have to be removed. I can only see on screw under the 242 and it doesn’t look like it is something that should be undone :thinking: so I’m waiting for some clear advice from somebody that Knows
what’s what here.
Only the 362bmr has an internal suspension system that requires the removal of transit bolts.
The 362 and 242 don’t have this.
