Hi guys,
I am trying to drive my kudos 707 with 2 x 250. Just wondering if it’s ok if one is 250-2 and other is the olive series. Or it’s absolutely critical that both amps need to be exactly the same?
Hi guys,
Wouldn’t the S362 need three power amps?
Just to check. Are you using a SNAXO 242 or 362 as you say in the thread title? The latter is three way Xover. You need the 242 with your speakers, and I believe it should be set up specifically for your Kudos.
As for the amp query, the general idea is OK as they are pretty similar. It might be interesting to hear any difference if one or other is on treble v bass etc.
Have you read the FAQ re active systems, and done a bit of a search re active Kudos? There is a lot of relevant knowledge and experience to explore here.
Bruce
The received wisdom in the past was to use the “better” amp on the trebles, and the “lesser” amp on the mid-bass.
Hi. New to this forum. Thanks for the tip. Will check the thread. I’m using a 362 designed for kudos T707
Not really. You can use 2 amps with the 362
I didn’t know that….how is is all connected?
Edit: found explanation on another thread.
Honestly I am not sure myself. Still waiting for my 362 to arrive. But I saw the connection guide in kudos website
The SNAXO for Kudos is specific to those speakers and very different the usual SNAXOs for Naim or older Linn speakers. I would advise you to get in touch with Kudos for further advice.
