Blacknote,
I hope you won’t mind if I’ll refrain from comparisons: I have been a Naim owner for many years, and had a large number of their 45-year long catalogue’s items. My M3 has also a costly streaming board and a remote with an insensate price, so its global price tag should come closer to an NDS’s.
I’ll tell you my impressions about the ND5 XS2, which I used with a Nait XS2: it was easy and very reliable to use, never lost connection or had network issues. Together, they were the pair that made my S-400s perform globally best in my living room, thinning down the 400s a bit and refining their top end another bit.
American and British audio ‘schools’ are very different; when I still listen to a Naim system I hear qualities unavailable elsewhere, a hint of sharpness that adds to the music’s ‘trueness’; on the other hand, in the long run I found it more suited to jazz and high class pop than to classical. They also played solo piano wonderfully.
I have always believed, and still believe, that once in a while Naim comes out with a product that - be it a clever stripping down job from a top class model, or the other way 'round - belongs in the entry level compartment but is a champion of cost/quality ratio; it was so with the Sats, the XS2 and the ND5 XS2 especially, which, in my opinion, doesn’t justify - if not for those for whom tossing another zero in the cheque is immaterial - the difference in cost of the NDX, even the 2.
The path along which Naim is slowly bringing its more iconic voicing - perhaps the ‘olive’ one - to a gradual universalization seems to stop, once in a while, on a happily affordable compromise; the ND5 XS2 is one and the Atom, to my ears, is another.
As you may know, I have Klipsch Heresy IIIs, which very likely are considered by some here inadequate and an out-of-time eccentricity on my part; but I have them, and I hear them. Well, they are very sensitive; I sometime think that if I had been smart enough to buy them first, I would probably now have an Atom, a less authoritative and top-class sound but a ton of happy music and more savings in my Bank account.
Hope it helps,
Max
e
