For reasons, I can’t go into I need to find some suitable new speaker cable for my system.
The speaker cable will be going between a NAP200 and some Castle Severn II speakers.
I am not looking to spend a huge amount of money and probably up to that £15 metre and two 4 metre lengths will be OK.
I know the amp has particular resistance and capacitance requirements of speaker cables but I am finding it difficult to know which will work as often these specs are not supplied.
I know of course about NACA5 but new that is too expensive but I could try and find some on eBay used.
As an example, I have been recommended that Chord Clearway X would suit but have never listened to this cable and can’t find specs to show if they are a good match.
Anyway, can you good folk help with a recommendation for me?
Professionally terminated used NAC A5 is exactly the same as new NAC A5. Give banana plugs a clean with some contact cleaner and they will outlast you and yours.
I would expect they would say that, & to be fair Chord speaker cable specs are nothing close to being a problem for Naim amps. I just don’t understand why they don’t publish them, its not rocket science.
I measured my Chord Odyssey when I first bought it, it has 0.6uH/m & 62pF/m. Very middle of the road, & with 5m per side it has 3uH & thats near enough, especially with a Supernait
Used Naca5 is an option for sure. I certainly have no issue buying used Hii equipment, several items in my system are used either as-is or refurbished. It is a good way to get some decent kit on a budget.
It would be easier if they did provide these specs.
The NACA5 spec provides a range of 3.5uH/56pF/31.5mOhms for the min 3.5m meters and up to 20uH/320pF/180mOhms for the Max 20m length. So what I was hoping to be able to do was find a cable that has a similar balance and is within that range.
As been said before, Linn K20 looks almost the same construction & size, & as such it’s specs will be similar.
And no surprise, they are 0.93uH/m & 16pF/m
(It’s the inductance (H) that’s important to Naim amps)
