What do folks recommend other than Naim NAC A5, which isn’t practical for my setup? Currently looking at Chord RumourX or Witch Hat N2 as they are similarly priced for 2 x 5m lengths.
I use Rumour x for Nova and PMC 25.21 and I really like it
If you are going to go the Witchhat route, get the Phantom speaker cable. It is everything everyone says it is and you will eventually end up with it anyway. Can’t speak about the Chord cable as I’ve never heard it.
Plus 1 for phantom…
