I have a NAPv175. I see a length of naca4 or 5 for sale that is just under 3 meters. I know of the 3.5 meter “rule”. Am I being naughty? Or will this work for the center channel?
It’ll work, but remember that this length recommendation is a minimum. Optimum is 5 to 10m if you want the best performance.
Thank you. It’s 4 or 5. I forget at the moment.
Either will be fine. ![]()
