Well, mine is a lot less - and a lot older… and ‘smaller’.
If it (a single ‘box’) cost more that about £1,500 - new or pre-loved, its no longer for me. Reality.
I recall commenting on yours previously, nice mix of old and new boxes.
DG…
A sticking plaster.
Does it work? What differences do you notice with and without the sound optimisation switched on (I assume you can toggle it on/off).
I cant quite get my head around how modelling can be a better solution than measuring the room resonances and then treating the room accordingly (not that I’ve done that to any degree)
I haven’t played with it, since the dealer set up. However, during the set up process, we did play round with the settings to see what sounded best.
If I recall, the settings we tried were:
We settled on the SO setting of No. 3. No changes to the layout since then, so has stayed the same.
At the time it sounded damn good, so we were happy with that.
DG…
