Hi I am just curious as to what is the benefit from the Spotify integration in the Naim app. It seems to step outside the app when opened so I am puzzled as to what the gain is?
Spotify is not integrated into Naim streamers in the way that Tidal and Qobuz are. The only option they offer is Spotify Connect, so if you choose it in the Naim app it takes you to where you need to be in the Spotify app.
Thanks very much Chris.
I am thinking then there is no benefit if you can connect to your Naim streamer directly with the Spotify app sq wise?
Correct.
I wouldn’t be using Spotify though if I was interested in SQ.
There is no benefit, as it’s exactly the same whether you open the Spotify app directly or via the link in the Naim app.
Thanks both. Was just making sure I understand this. It seems to me you might be better off using Qobuz rather than Spotify, even if Spotify offered SQ similar to Qobuz, as Qobuz is better integrated?
Spotify wants to control the user experience and use it to control their brand and market their services. There is not much business in just supplying audio data - that is a very small business.
Almost in the same ballpark there was news today on the shareholder action against Block and their purchase of 88% of Tidal a few years back. The complaint was that Tidal is commercially unviable and that should have been obvious. The judge threw it out saying that while it may be true Tidal is a mess it is not illegal to be stupid and make bad calls.
There are pros and cons to consider. Tidal gives you the choice of Connect, like Spotify, or native control from within the Naim app. Qobuz has no Connect option, although they have been making vague promises about it for years.
Some prefer Connect because some fearures of the Qobuz or Tidal apps are not available in the Naim app.
OK I have got it. I can remember a discussion in a Linn forum on the merits of different ‘controls’ for SQ. Thanks for the advice - I have got it now. One last question if I used Deezer as a remote control it would not be as good as it is not integrated like Qobuz etc?
I like Spotify, I know that it is not lossless, but sometimes I find it more musically and enjoyable than Roon+Qobuz streaming.
Qobuz and Spotify do sound very different indeed, that’s for sure.
What amp, speakers and streaming source are you using?
linn dsm/3 → nac 552 → nap 500 → dynaudio s5.4
Hi thanks,
I am thinking Deezer (or any other non integrated service) is not going to be as good as it is not integrated in the streamer in the same way as say Qobuz is?
Bear with me. Talking about SQ - my thinking the software in the streamer would favour apps that were integrated. Or whether the app supports the service or not is irrelevant and the software in the steamer is agnostic as to the control.
If so then the benefit of integration in the app is just ease of use.
Very nice
. Absolutely no doubt that you can hear the difference between Qobuz and Spotify then. I much prefer Qobuz to Spotify - whether it’s through the Naim app or via Roon. The two are like night and day to me. A crazy hobby but it keeps me sane…kind of… ![]()
OK thanks. I have got it now - thanks to all for all the info and input.
And yes Qobuz sounds significantly better than Spotify, to me, however it arrives.
