Would a Naim NAPSC power supply work with a Stageline phono stage?
I currently use a Naim Nait XS2 amplifier to power the Stageline, but wondered if purchasing the NAPSC would be beneficial?
No. You will need at least a Flatcap to power the Stageline.
Thank you
Or an i-Supply!?
You could, although not all Stagelines can be powered by an i-Supply - only later ones with 2 DIN sockets. As the OP is currently powering from the NAIT XS2’s AUX2, I don’t think an i-Supply would represent much of a performance uplift, if any.
