Looking for speakers for the above (2nd System)
Any recommendations. Budget £2500 Max
Speakers very personal choice, and dependant on your room/listening space. New or used? Ideally you should try for a home demo. Neat, Kudos, Focal, Dyna etc are amongst your options.
I’d have no hesitation recommending one of the Kudos range.
I use X3 obviously not standmounters but I find the gel of these manufactures outstanding.
No pun intended. ![]()
