Good approach.
I am currently pinned down by one of the cats so not a great angle for a photo but here is my espresso machine
Iāve just had my first coffee from this attachment to my Aeropress. Impressive crema ⦠and flavour consistent.
Iāve just bought this bad boy of certain online auction site. Never had a lever espresso machine before so itāll be a bit of a learning curve before I get some really good espresso out of it.
İt was a very fast upgrade from Lelit Grace to Mara X
Both great machines and i like the home espresso
A very steep slippery slope thenā¦
The Elektra isnāt difficult to learn once you have got the grind and dose right. Leave a little headroom in the basket and let the spring get on with it. Provides nicely-layered shots. Great for Yirgacheffe.
Very nice! What is it? A Bezzera?
A Londinium - very popular as a prosumer lever machine around 6-7 years ago (donāt know how popular it is now). It was commissioned by a NZ guy who had the Londinium roastery in London (but has since moved back to NZ) according to what he wanted. Built by a midlands espresso machine maker (cannot remember who) to his spec. Very good and will keep pressure going happily all day long with heavy use
Edited to add - think it may be Fracino
I didnāt recognise it. Yes, Iāve known Reiss since he started Londinium and still lived in London. He used to sell Olympia machines and I bought a Cremina off him, which is how we met. Heās a great a guy and has done something really special with the Londiniums. Thatās one of the very best spring lever groupheads and used in many well known Italian pro machines, including the Bosco.
I hope you have paired it with a suitably wonderful grinder
And yes, it is Fracino.
Itās an Ethiopian coffee bean. An amazing one with a complex flavour profile
Thanks!
(A bean - just a single one in the world? Must be hard emulating that without destroying it for future reference!
Ah, grinders. I do have a bit of a weakness there
firstly the londinium needs a service and has done for months - been v60 pour over for ages. So I havenāt yet used my latest grinder - EK43 (bought used at start of lockdown). Not found a place in the kitchen for it yet that my wife will allow
but the intention is for it to replace my HG one (used for espresso) and my niche (used for pour over). Though I may keep the HG one for decorative purposes and the niche for holiday use
Indeed! Built in Birmingham by Francino - who make machines for several companies.
I hear thereās a Londonium Compact in development. Apparently it should be available early next year!
Iām still working on getting the grind right. Itās loads coarser than I would have expected.
Thatās strange, it will choke on Turkish-style powder grind but still likes a reasonably fine grind. Is the machine new? Have you weighed the dose, just to set a benchmark?
Itās used and probably close to 20 years old but in good condition. The flow is pretty good and after a little adjustment the pressure and temperature is spot on.
Iāve ordered some new seals and a new spring which Iāll fit over the next few days and see what happens.
Forgot to say, Iām using 16g per double espresso and aiming for about 30g of espresso.
16g is about as high a dose as the Microcasa can take. Lowering the dose may also let you grind finer, depending on the bean/blend and above all roast.
If it leaks a bit of water through the grouphead heating up and cooling down, thatās a good sign new seals are needed.
Type of bean(s), temperature and length of roast, fineness of grinding, quantity of grounds, firmness of tamping, temperature, pressure and flowrate of water, final volume. (That is before any other options if not drinking the neat coffee.)⦠Puts a Japanese tea ceremony to shame! Anyone for Maxwell House?
