I see this message in my naim app. With NDX-2 version 3.10.0 (5598)
Each station move and insert is a lot of work. Could it be faster (simpler)?
I’m sure that’s a no.
I just did mine one by one.
For example, delete Frisky Radio, then do a new search for Frisky Radio and save it to pre-set location 4.
Repeat for the other stations.
Is Frisky Radio some sort of soft porn channel, where people ready saucy material?
Just listen to it. You have to love it, great dance/techno sound ![]()
A lot of your channels sound a bit dodgy. Deep. Frisky. Intense. Is there an Orgasm Channel?
You like a listen session?
Why will it expire?
Naim have a new way of providing iRadio, moving away from vtuner. That’s why you need to retune to the new versions.
Most are expiring due to the change over from V-Tuner to Naim’s own radio tuner.
There is however no hurry, because the vtuner service will be maintained until Naim have released the firmware updates for muso/Qb gen 1 and the green screen streamers and unitis, and given time for those firmware updates to be implemented by customers.
