I have a nap90 and nac 92 with a flatcap all running well. If I replace the fc with a CB hicap all runs well. When I replace the cb with an Olive hicap I get a loud hum from the speakers - typical of an earth loop.
The cb hicap normally is on a 32.5/250 cb system. If i replace the cb hicap with the Olive hicap here there is no earth hum .
Ok, further messing has identified it as the Olive hicap. If I connect it and then leave it for 5 minutes turned on the hum goes away. Another box to go to Darran. He is going to be a busy chap.
