Streaming Apple Music with bit-perfect playback
Looking for a way to stream Apple Music at its native sample rate with bit-perfect playback? Check out Arco 0.5.0b2 on GitHub ( Release Arco 0.5.0b2 · renebouwmeester/arco · GitHub )
Developed by Rene, a Roon community moderator, the app is still in beta, but I’ve been really pleased with it. I’ve been using it to stream to Roon and to my Linn streamer via UPnP.
You can also go to the Roon Community forum, search for the topic “Another way of playing Apple Music in Roon” by RBM René for details.
I just wanted to add that you can stream UPnP and Spotfify lossless (in addition to Apple Music) seanlessly.
The following shows how one user can stream Spotify lossless to his Linn streamer using the Arco app:
I tested it myself, and found no loss in the SQ.
I have been testing Arco to play Spotify lossless, and Apple Music lossless on my Linn next-generation Klimax DSM using Linn OpenHome UPnP, no Roon subscription is needed. So far, it works almost perfectly except a few minor edge cases.
Below is quote from Rene, copied from the Roon community forum:
"I ultimately solved the ‘bit-perfect, anywhere’ issue for Apple Music by building Basso. Arco is leveraging the same technology without the overhead of an entirely different App.
The Roon route was the obvious one, but has some limitations. UPnP offers more flexibly, but requires some adaptations for offroad devices. It works 100% for KEF, Naim, Wiim, etc. Linn is a bit more idiosyncratic. It mostly comes down to getting the specific timings right in every step of the chain: Music app, the clocking bridge and the UPnP (or OpenHome) delivery while dealing with a few device specifics."
Overall, I’m delighted that I can now stream lossless audio from both Spotify and Apple Music without compromising sound quality. To my ears, it might even sound better than Roon—though that could just be my imagination.
That’s great, but does it sound better than lossless Tidal or Qobuz used without Roon? I drifted away from Roon because it didn’t sound that good on Naim streamers. The best sound I got from Tidal and Qobuz was using BubbleUPnP Server on a NAS as a proxy server.
Yes Chris, when I mentioned Roon, I implied both Qobuz Connect and Tidal Connect because I don’t hear the difference between the three. But as said, it could be my subjective judgement.
