Streaming upgrade
Hi all,
I wanted to get your thoughts on something.
I currently have a Nait XS3, a FlatCap XS, and a Sonos Port for streaming. I also have other Sonos gear throughout the rest of my house, so ideally I’d like to keep the port for convenience.
However, like many of us, I seem to have caught the dreaded upgrade bug and am wondering whether there are any worthwhile upgrades that would help me get the best out of the Port and my current setup.
For example, I’ve been looking at adding a separate DAC, perhaps a DAC-V1 which won’t break the bank, or a nDAC? I’m just not sure whether it would make much of a difference!? I’m also mindful that the Port will always be the weakest link regardless of any upgrades.
Any thoughts?
Jon
Hi, an NDAC would be great with the digital out of your Port. The V1 is nice too, although not in the same league as the NDAC.
Yes, you could probably improve things further by getting a better digital transport than the Port, but the quality of the DAC is most important.
Hi Jon
I guess you can go with upgrading the DAC and/or streamer depending upon budget.
On the DAC side, I had a Chord Qutest (before recent upgrade) which improved the sound quality of my system. This has/still has the Innuos Zenith mk3 as a streamer/server.
I also have Sonos port linked to the Innuos which allows for connection to various Sonos amps throughout the house.
Best getting to a dealer and listen to potential upgrades to the DAC and/or streamer to decide which is best for you.
Good luck.
I’m a longtime Sonos user - back to the original days of 2008 but I’ve tapered down over time; a Port into a DAC should be fine if you’re getting bit perfect outputs from the digital coax. That’s a key point to research as earlier generations of Sonos gear had some measure of DSP built in that users couldn’t get around. The old Connect was good, but that forces you backwards into the S1 app.
If that’s the case, a Bluesound Node is a much better option.
My Sonos Connect is S2 compatible not sure if it’s bit perfect though, I used to run it into a Rega DAC which was a big uplift in sound. It’s now connected digitally into my study Superuniti.
Thank you for the comments and suggestions so far. Food for thought!
Why not go for.an ND5XS2? One box, streamer, DAC. And perfect match for your XS3.
Thanks everyone.
I decided to pull the trigger on a used ND5 XS2.
I’ve only had it for a couple of days, however i am very pleased with it. A huge improvement over the sonos.
Now to let the bank account recuperate for a month or two!
Congratulations and enjoy your great system!
