I just upgraded from a SN1 to SN3 (setup includes HICAP DR, Super-line, HDX and DPS 2). When I look at the manual how to connect the Super-line with a HICAP and SN3 I don’t see any connection diagram, only for Stage-line with SN3/HC.
Is the connection setup of the Super-line with a SN3/HC the same as Stage-line with SN3/HC??, I recall with the SN1 it was different.
I have noticed two things after I connected the equipment different as with the SN1
The sound seems lower with the SN3 at the same volume level settings compared to the SN1
The NAIM logo light from the Superline is not completely lighted up (corners seem darker)
Don’t know if both things are normal, can any share their experience?
thanks!
OK thanks. This looks like the logo “bleed” that some logos had a few years back. Your dealer should be able to replace the logo for you - it’s a fairly straightforward job.
One suggestion here; the Superline is very sensitive to large transformers close by, so you may well get much better performance from it not having it side by side with the Hicap. It’s worth experimenting with different positioning.
