I just got a used Supercap DR to use with my 282. It came with no accessories…I know I need two 5 pin 240 SNAICs to connect, but if I’m not using the Burndy socket do I need a link plug at all?
Thanks in advance!
Thanks in advance!
To connect the SCDR to the 282 you just need two SNAIC5s, no link plug needed.
Check out the manual for connections:
There is no such thing as a Burndy link plug for the Supercap DR. It isn’t needed.
Ah - great! Thank you all…now I need to find where the heck I put my old SNAIC!
