Can DR Supercaps be serviced by Naim today?
Check with your dealer. Naim recently reported that they were having to triage service for DR units as they were very short of DR capacitors and were awaiting further supplies.
Yup, mine needs a service too, but holding back until spares have stabilised for service rather than repair.
How does one know if a Supercap needs servicing?
@Richard.Dane A question,an Olive Supercap serviced by Naim
in say -2015,doesn’t it have the same kind of Felsic capacitors as the Classic series?
If the Olive Supercap was relatively recently serviced then it likely would have Sic Safco/Felsic main caps fitted, which replaced the previous SLCEs.
Thank you . That would mean that it now has the same service interval as the Classic series ?
I would guess so, but probably best get Naim’s input on that as it’s their interval recommendation . @NeilS ?
Yes, same for olive, classic & DR Supercap.
Neil.
Good spot. If the internals are now the same, then what drives the service interval will also be the same.
What is the recommended service interval for a SuperCap DR, and a 300PS DR for that matter?
As above, 12-15 years
Thanks. I thought that was about it. Mine are 2018/2019 production. I think the service for my 252/300 will be the next owners’ problem. ![]()
Ours would be due service in 2036.
Whether naim will be servicing them at that point is anyone’s guess. One of the selling points of naim was their strong service ethic, but it feels like there have been loads of posts recently where one by one products actually can’t be serviced. Whether due to board design, no spares, component shortage….
I don’t plan to have my 252/300 at the point it needs 12-15 yr service. I found an upgrade I think sounds much better. ![]()
The component issue was temporary. I had to wait a few weeks to get the first of my 555DR-PS serviced by Class A but it’s been done and is due back tomorrow. The second one is going in for its service this week.
What is the upgrade?
Boulder 1110 and 1151 monoblocks. I already have the 1108 phono-stage.
Similar cost to 552/500.
