Hi.
I have just purchased a SCDR to replace my HCDR to pair with my NAC 282 and NAP 250DR.
I have a single Super lumina SNAIC
I have the original SNAIC.
Can I use them on the SCDR-
One for power and the other signal?
Kind Regards
Peter
There is no such thing as a SuperLumina Snaic. You need two Snaic 5s to connect the Supercap to the 282.
Diagram is here for 282 plus supercap and napsc.
An interconnect like the superlumina is a 5 pin 180 degree plug.
A 5 pin snaic is 270 degrees.
You want two identical SNAICs for the full monty connection of a Supercap to a 282. You only have one. I once had this combo and had to buy a second matching SNAIC.
As mentioned above there is no such thing as a Super Lumina SNAIC. Thatâs an IC and wonât work for this application.
Instead of buying a 2nd SNAIC you should just pass Go and get a 252. That includes the Burndy and SNAIC you need.
You should use near identical Naim SNAICâs.
Do Not Use Anything Else. Please�
- 1
I wouldnât be that concerned about identical SNAIC5s since only one of them carries an audio signal.
Are you sure about that? I was told each one carries audio for each channel. Same as if putting two HiCaps on a 282.
@llatpoh76 is right. Only one of the SNAIC5 cables between SC and 282 carries both audio and power. The SNAIC5 connected to upgrade 2 on the 282 is power only. Same as with two Hicaps powering a 282.
OK. I see. Thanks for the explanation.
You can see on the back panel what does what; top one âpowerâ, bottom one âpower + audioâ and the pin diagram includes ch1 and ch2.
I probably could have looked at that myself. I have two.
Donât forget that the Snaic you have âbelongsâ to the Hicap and would need to be sold on with the Hicap if/when you sell itâŚ
Apologies for getting my question wrong.
I have had a stroke.
Itâs a standard snaic and a non-Naim âsnaicâ. Would there be an imbalance and disaster if used?
I strongly suggest you replace it with the genuine article. Note that use of non-Naim SNAICs is considered an unauthorised modification to Naim equipment, hence discussion of them here is not permitted.
