A conundrum…. I recently disconnected my 250 from the Supercap and replacing it with a 140 whilst it goes off for servicing.
However I didn’t check what socket was used on Supercap as I had to use a different cable. So checking the connection guide I duly used socket #3.. only to find it producing some weird noises. I then switched it to socket #4 and lo and behold normal service resumes.
Am I going mad in that the connection guide is wrong ?
Or is it a case that the 250 uses socket #3 but the 140 is #4?
Maybe the DIN socket on 3 is worn or dirty and making a poor contact on one or more pins. The pins and sockets are self-cleaning so have you tried plugging and unplugging with a DIN plug on that socket just in case it’s dirt/tarnish? (obviously only do this when all is switched off).
I noticed a while back that the manual shows different Supercap outputs used for the power amp depending on whether you had a 52 or an 82. I presume the reason for this is to use the shortest possible signal path, and it’s just coincidence that @beermonster is using the socket recommended for 52 users with his 82!*
