You can try the various resistance plugs provided with Superline starting from 100 Ohm and see what you think about the sound.
Less ohms plugs in my system means more low frequency presence
My Temper V worked best loaded with the 500 Ohm and the smallest of the capacity plugs. The 100 Ohm and no capacitive loading was pretty good, but came with radio Moscow playing along with the LP.
