Supernait 1 preout voltage?
Hi
Anybody know what the preout voltage is from the SN1, currently using it as a preamp into a purifi dual mono poweramp until funds permit to change to a dedicated pre.
Also i am using the sub out on the sn1 to the poweramp as the manual states its the same output via this and the dedicated preout. Is there any benefit of removing the link plug that attaches the pre to the power part of the supernait to allow for different power supplies, will the power amp part of the sn1 be disconnected and just allow the preamp of the sn1 to be used?
TIA
Hi, you can’t do this, this is how power (as in electricity) reaches the preamp.
