Hello everyone, i have a supernait 2 with some buzz issues and i’d like to connect it to a nap 200. Id like to use the SN2 as pre and nap 200 as final to test if the buzz issue disappear.
I made some test with nap 200 and another pre (nad) and i didn’t have buzz issues.
How can i connect the nap to SN2 as it can be just a pre
I haven’t experienced something like that - with my SN2 and previously xS2. Maybe it’s worth it a try with other el socket or friend house - for example.
Well, The SuperNait2 has got an internal DR powersupply module for the preamp. You don’t “need” but probably would be a bigger step forward with DR version.
