Supernait 2 NDX2 Connection
What input should I connect the NDX2 to on the Supernait 2, there is no streamer option?
Thanks, Nick
We use CD on our 252 (streamer isn’t a label as streamers were not a thing when these boxes were designed).
You have a few options, the labels are just names.
Supernait 2 HDD/AV carry outputs and Aux 2 has power. See Reference Manual section 4.2
Careful with AV input, there’s a bypass switch for use as a power amp only. Section 4.6
CD or Tuner therefore most appropriate - input only DIN connections.
Thank you
