Supernait 2 Speaker pop left side
Two issues with Supernait 2…
I am familiar with naim amps making small switch on pop through the speakers, however i have it on left speaker only and twice as loud as previous Naim amps owned..
Also get a pop when mute/unmute which never had with previous Naim amplification..
Switching sources whether with facia buttons or remote also causes same pop through left speaker.
Should i get it looked at or live with it..?
If it was me and both channels sounded great and it was not coming up for a service I would leave it.
Yes it sounds great, have edited original post to add “switching sources also get same pop through left speaker”
I had a popping when changing channels on a naim amp. Contacted naim and amp was sent in for attention as I was told this was not right. Turned out to be the tantalum caps needed renewing. Silent switching when returned to me.
This was correct and confirmed by dealer & naim, supplier swapped amp for me to newer one had in stocks..
