ATC SCM19’s like all ATCs only come alive when the volume is higher.
In the past I have back to backed my ATC SCM40’s with my Kef LS50’s and a friends ATC SCM19s. The 19’s did require more volume than the other two to get up to a similar listening level. They also lacked bass compared to the LS50’s and especially compared to the SCM40s. The 40’s also have a warmer nicer mid range.
No. Did not. Which amps do you use? Or how does this work exactly? Thank you
I own a sn3 but I tried sn2 and 200dr biamp, you could see your 40s flighting
@piebia Out of interest, do you have your SCM19s set up in an equilateral triangle with the speakers facing your listening position, as per ATC’s owners’ manual?
Ciao @Christopher_M honestly no, I cannot achieve this setup in my house, it is triangle in which height is bigger than base
Understood. I have found ATC’s recommended positioning gives a more vivid presentation. ie. with the speakers pointing straight to your listening position. Very enjoyable!
