I currently have a Supernait 1 with a Prefix phono attached to Aux 2. I would like to know if I move to a SUpernait 3 will I be able to continue using the Prefix into Aux 2 and also have another turntable connected to the Supernait 3’s MM phono stage? I would like to be bale to just switch inputs to play each turntable (not have to unplug, re-plug, power off etc!).
As the inputs marked ‘Phono’ were directly under the Aux 2 socket I had a hunch this might sadly not be possible?
Thx in advance for whoever knows the correct answer.
I am assuming that now the DAC is gone there is no need to also have the ability to program inputs to front buttons? If so I like the extra simplicity. Supernait 1 has been terrific but ready for a 3!
