Supernait won't come out of strt-up mode
My ancient SN1 is stuck in power-up mode. The two Mute buttons remain illuminated. I think the amp got a power surge after a blackout. Input and Monitor selection buttons seem to “work”, but it remains resolutely muted. I tried the front-panel reset by powering on while holding the mute buttons, but it didn’t help.
Any ideas? Thanks in advance.
Winky - A quick thing to try would be (with the SN powered off) to unplug and re plug the link plug a few times. I’m assuming you’re not using a Hicap with the SN ?
@NeilS may have some ideas here
Classic symptom of a capacitor failure in the brown out detect circuit.
Neil.
Yeah, that’s what I figured.
Yeah, I was using a HC. Suspecting that, I replaced it with the link plug. Still no good.
