Superuniti display flickers
Hello,
I have a Superuniti and every time I change the volume, pot or remote, the display
starts to flicker…volume and normal display change between tenth of seconds.
Aside from that, I cannot swich off the display. “disp” button doesn’t have any effect.
I bought the Superuniti with this issues and changed display and flat cable…nothig changed.
I assume the problem could be any IC?
Thank you
