the right hand channel of my Superuniti has suddenly stopped working. I’ve tested speaker and cable and know that they’re not the issue.
I understand there’s now a standard price for all Superuniti repairs; I’m also we’re aware we’re in the midst of an exchange programme so it could be time for an upgrade. However - is it possible there may be a relatively straightforward fix for this? I appreciate the issue can’t properly be diagnosed without someone opening up the unit, but I would be glad to understand (a) whether this is a common issue and (b) whether there may be a common solution!
If it’s on the amp side then it’s likely repairable/serviceable I would have thought. Best check it out with your Naim dealer who can then liaise with the factory.
Of course, the exchange program running now in the UK is rather attractive and may work out as the more sensible option, so worth considering.
May I ask one further question, as a direct comparison is likely to be difficult in the circumstances - can you see any reason why one wouldn’t go for the upgrade route to a CI-Uniti, when that route is basically the same cost as a service/repair?
The CI-Uniti certainly seems like a great bit of kit for the money, although I’ve yet to hear one myself. I’d be surprised though if it outperformed the SU as a pure amplifier. The big advantage over the SU will be the up to date Streaming engine, so if that’s of great importance, and performance is good enough, then it probably makes a lot of sense.
I had a Nova on loan from my dealer but I had a similar problem with it - one of the channels was not working at all. I also read somewhere on the forum that someone else had a similar problem. In both cases it was a capacitor that was at fault and an easy fix in Naim. Hopefully your issue is similar.
Thanks for your reply and that’s encouraging. I am just considering my options as £450ish seems like quite a lot of money to have to spend on a potentially simple repair, especially on an ageing machine which could develop a different fault the next day!
