Support required
Hey there
New Naim
Unboxed my Uniti Atom headphone edition.
Didn’t get very far.
Remote wouldn’t pair. Tried every possible fix that was online, all to no avail.
Getting a flashing power light. 4 times then once then 3.
Not sure if this forum is for this but im pulling my hair out.
I am afraid that sounds like it’s time to get back in contact with your dealer.
Contact your Retailer.
I’m thinking the same.
cheers
Would contacting Naim Support direct be another option ?
Your dealer will get a quicker response from Naim than you will……i would go back to dealer and get it swapped for a new one.
Thanks for that.
Exactly the same experience. Pain & heartache aplenty,
Will be contacting supplier today.
