I m using Apple Music subscription because it is the only streaming service working in egypt without vpn. Right now I m always on vpn and it worth to subscribe tidal or quobuz.
Now the doubt is: tidal, quobuz or Apple Music? What is the best sounding streaming service?
Do the subscriptions work through a VPN? If so you can of course try them for yourself. There is usually a free trial period available.
Many services are stricter than they used to be, so in addition to a VPN you will likely need a method of payment registered in a supported country, and even then it may not work.
My choice would be Qobuz if you can get it, although I would consider returning to Tidal once their post-MQA transition to 24 bit streaming is completed.
