Hi all,
I just received my new nss333 to go along with my 332 and 350’s
When I click the brightness button on the 332 remote the brightness changes on all separates.
However if I do the same on the 333 remote only the 333 and 332 brightness changes.
Is this by design?
SA between 333 and 332 is wireless, whereas the 350s require the supplied cable to be installed. So I’m guessing that perhaps the 350 has not been set up to use SA?
The cables from pre amp to 350s are installed, I presume correctly as clicking the power button on either remote or separate turns them all on/off.
the preamp remote can change brightness on all as well you not the 333 remote
I only use and paired the 333 remote, this does everything you need. My 332 remote is still in the box.
system
Closed
December 30, 2025, 6:31am
5
