System Pics 2019
Yes the BDI Stand holds my AV receiver, Oppo 93 and 3 channel amp. 272//XPSDR/250 Dr sits on a Standesign rack. I got it dirt cheap. I may upgrade it to a Fraim or Quadraspire one day but I’m in no hurry to change it.
Naughty naughty, you have things between your speakers :roll_eyes:
don’t bother Spurrier, it’s a joke! ( see some posts above)
Mike, i found your past system on pinterest. I saw S Mike naim pics, so i thought of you. There is a lot of past naim forum system pics on pinterest. Is it you?
Not me I’m afraid, I don’t use Pin Interest.
i found nice naim systems pics on pinterest. The systems are from 2016 and before. I am sure some will recognize them . I found them via google then Pinterest.
Can you identify them? Just for fun and pleasure. These are all nice and interesting.
The ones with library and Ovators S400 are mine.
One can see an evolution of my system - from SN2 based one to the current 252 + NAP300DR + NDS :slight_smile:
it’s the 1st and 9st pics?
The ash designs stand with Gyrodec is my old setup, wow how my system has changed over 3 years.
You should rename yourself in forensic rooster!
:small_blue_diamond:Frenchrooster,…This system owns a Swedish guy,.I mention no names.
He was a member of the old forum.
I do not know if he is here yet,on the new forum.
/Peder🙂
you still have the gyrodec? this deck is nice looking.
there is a sub ( brown) ?
perhaps some systems here have not changed? if i understood well the forensic term. It’s for ancient or died object or persons?
“Forensic” refers to the use of scientific techniques in connection with the detection of crime.
On this occasion, I believe that Ardbeg10y was referring to your good eye in noticing or recognising people’s systems from the images.
thanks Graeme for this precision. The google translate is not accurate.
However i am not sure that all these systems are from naim forum members. We will see.
:small_blue_diamond:Frenchrooster,…I interpreted Ardbeg10y’s post as a compliment.
You’re good at finding,searching things up.
Just look at the journalist pics-thread,.
That’s why I liked Ardbeg10y’s post.
/Peder🙂
thanks Peder. I was not sure at 100% first that it was a compliment.
I tried to find system pics from the 80’s or 90’s, but could not found.
Those Ovators are handsome devils…
the room is very little. The speakers were in an another room?
