Keep well my Frenchie
As others have said, I think you have a missmatch between electronics, speakers and the room. One potential cost effective solution is to add another sub, or a couple more subs. In my experience, a second sub does more than the first. Subs will help fill the room and perhaps make the current speakers sound a bit more relaxed.
Good luck.
Hans
And you, when will the isolation finish? How is the weather and temperature now?
Weâve had a soft lockdown which thankfully has worked and it looks like things will slowly get back to normal. Fingers crossed of course.
Itâs been long since I posted over here. Probably on the old forum.
This is my actual setup. To my ears, it sounds fantastc.
MArco
Olive awesomeness!!
Marco, what make is the left hand rack - I could do with something similar for my half width boxes.
Chris
Itâs a design classic : USM-Haller
You can assemble it the way you like it, a bit like LEGO.
I put mine on SoundcareÂź SuperSpikes
looking great! what did you use to bring that sine though? I bough some restorer sometime ago for my SL2s but havenât got around to using it â system is sounding so good I donât want to disturb anything - neurosis or what!!
Hi Ken - what was the name of the restorer you bought?
We go to what we call Level 3, which is close to Australiaâs full âsoft lockdownâ next Tuesday, for at least 2 weeks, then hopefully go to Level 2 - which would then be close-distancing (1m - no kissing strangers) and no large events.
Weather has been lovely, calm sunny Autumn days, around 20 degrees. Bit of rain today, but our water restrictions have now gone up to Level 3 as we have an extended drought heading towards winter!
Very shiny Mario, is this now with the new tweeter plates ?
Enjoy
Wired direct to the router upstairs is much better, but lacks WAF!
Will get routed properly once my mate turns up with his through wall drill.
WOW, simply WOW!
Beautiful room.
I think the chrome bumpers really hold the room together.
yes new plates, will do a reseal of the bass cabs soon, and Ronseal on the top cabs, not much spike damage, but may as well go whole jog. Must do screen install first.
Polish is just a local product called âOâcedarâ oil based, i wipe it on and off in an hour or so, timber can dry out otherwise over many years.
Hi Dave, sorry for delayed response:
it was âHoward RF1016 473ml or 16oz-Restor-A-Finish, Neutralâ and I bought it from Amazon
enjoy/ken
